JayT11
Dec 14, 2022Follower
R8000P losing name wifi
So i have been using the CM 1200 and the netgear R8000P for 2 years. Then i got my new home internet from TMobile. So i tried the new wifi,and i did try to connect the r8000p to the Tmobile home inte...
Dec 15, 2022Guru - Experienced User
The CM1200 is a modem only, would not have any wifi.
Be sure the R8000Ps wifi LED button on top is ON and enabled. Press it for 5 seconds then release if it's OFF.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
