JayT11
Dec 14, 2022Follower
R8000P losing name wifi
So i have been using the CM 1200 and the netgear R8000P for 2 years. Then i got my new home internet from TMobile. So i tried the new wifi,and i did try to connect the r8000p to the Tmobile home inte...
michaelkenward
Dec 16, 2022Guru - Experienced User
JayT11 wrote:
So i switch it back to my last wifi but it gone. Wifi name,and even i cant connect it back to nighthawk app. Any recommendations?
You can't just switch between devices by unplugging the R8000P and replacing it with the unnamed "Tmobile home inter thing" and back again.
Not sure what "it gone" means, but when you change your network hardware, you should restart things in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
