Mister62
Jun 15, 2021Aspirant
R8000P My router won’t e-mail the logs to my gmail account
My router won't email the logs to my gmail account. Message: email failed 5.7.8 Username and Password are not accepted. I have triple checked the username and password.
- Jun 16, 2021
Mister62 wrote:
I am using:
smtp.gmail.comIf it doesn't send a test message, then maybe gmail won't work.
I couldn't tell from your first message meant by "Username and Password are not accepted". You didn't say which username and password. If it was the email ones, that would explain it.
I vaguely recall that gmail doesn't work with logs.
Outlook.com works for me, and you can get a free account.
michaelkenward
Jun 16, 2021Guru - Experienced User
Which mail server are you using for the SMTP settings on your Your Outgoing Mail Server?
Not all servers work with the log settings.
I use outlook.com.
Mister62
Jun 16, 2021Aspirant
I am using:
smtp.gmail.com
Thanks!
smtp.gmail.com
Thanks!
- michaelkenwardJun 16, 2021Guru - Experienced User
Mister62 wrote:
I am using:
