notgoodatthis
Aug 25, 2022Aspirant
R8000P Nighthawk Router is causing delay internet, but works great when connected direct to modem
I have my PC connect to my Nighthawk router with a LAN cable and my router is connected to my cable modem. When I access any website there is about a second or so delay before it goes to the website...
- Aug 26, 2022
Power OFF the ISP Modem for 1 minute then back ON. Then walk thru the set wizard using a wired PC and web browser at 192.168.1.1
Aug 25, 2022Guru - Experienced User
- notgoodatthisAug 25, 2022Aspirant
Firmware is V1.4.3.88_1.3.50
Cable modem is Netgear CM500
- FURRYe38Aug 25, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is Armor, Circle, or Traffic Meter enabled or has those ever been enabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
Installed new Cat 6 cable between the router and modem
powered off everything as said
turned back on
still has same dilemma
