notgoodatthis
Aug 25, 2022Aspirant
R8000P Nighthawk Router is causing delay internet, but works great when connected direct to modem
I have my PC connect to my Nighthawk router with a LAN cable and my router is connected to my cable modem. When I access any website there is about a second or so delay before it goes to the website...
- Aug 26, 2022
Power OFF the ISP Modem for 1 minute then back ON. Then walk thru the set wizard using a wired PC and web browser at 192.168.1.1
notgoodatthis
Firmware is V1.4.3.88_1.3.50
Cable modem is Netgear CM500
Aug 25, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is Armor, Circle, or Traffic Meter enabled or has those ever been enabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- notgoodatthisAug 25, 2022Aspirant
Installed new Cat 6 cable between the router and modem
powered off everything as said
turned back on
still has same dilemma
- KitsapAug 25, 2022Master
Who is your ISP?
Do they support IPv6? If yes, be sure and enable it in advance settings on your router.
You might have to check out some alternate Domain Name Servers from those provided by your ISP.
- notgoodatthisAug 26, 2022Aspirant
I appreciate all of the help but still not having much success. Is there a non wireless router (wired router) or possibly a switch that might be better? At one time this R8000P did not give me any issues but I live in a very small town and not many computer savvy people around here to help.
