jlb4436
Nov 01, 2022Tutor
R8000P Nighthawk Router is causing delay internet
Me too! I have updated firmware to 1.4.4.94. This is the second R8000P that I have had. I returned the previous one because it wouldn't update at all. I am about ready to quit Netgear. I have tried r...
Nov 01, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is Armor, Circle, or Traffic Meter enabled or has those ever been enabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
