jlb4436
Nov 01, 2022Tutor
R8000P Nighthawk Router is causing delay internet
Me too! I have updated firmware to 1.4.4.94. This is the second R8000P that I have had. I returned the previous one because it wouldn't update at all. I am about ready to quit Netgear. I have tried r...
jlb4436
Nov 01, 2022Tutor
The modem from my ISP is a Zhone model 6381-A5-200. I have done a reboot on the modem, router and computer. The LAN cable has been changed to a CAT 6. The only thing I have not done is a factory reset on the router. I tried Armor, but didn't care for it, so canceled it.
Nov 02, 2022Guru - Experienced User
Your model modem seems to only support 100Mbps. The R8000P is supporting of 1000Mpbs.
You might consider checking on your modem. Might ask the ISP if they have something supporting of 1000Mpbs on the WAN port. Ask for a stand alone modem with out any built in router as well.
- jlb4436Nov 02, 2022Tutor
Thank you. I will ask.
