JohnBecker
Jan 29, 2024Tutor
R8000P Nighthawk router not working with Eero Pro 6E
After trading-in my Zyxel modem with the Eero pro 6E, my R8000P Nighthawk router no longer works. My ISP is Altafiber and I'm using fiber optics. Cat 6 is my cable from my ONT. Any help would be ap...
- Feb 03, 2024Since the eero is managing DHCP, it'll have the address in it's attached devices page. Look that up in the eero and use it to access it
Jan 30, 2024Guru - Experienced User
So how are you actually doing this?
altice gateway----->eero?---->R8000p?
If so, just put the netgear in access point mode.
JohnBecker
Jan 30, 2024Tutor
Fiber Optics to ONT to Cat 6 to "eero Pro 6E" to Nighthawk R8000P.
Now I'm trying to work around the Nighthawk and just use the eero for all of my connections. Progress is slow.
I got a security camera to work. I'll try the same procedure on the others.
My Grizzl-E Smart EVSE remains a mystery.
- plemansJan 31, 2024Guru - Experienced User
If you're connecting the R8000P to the Eero, put the nighthawk in access point mode.
- JohnBeckerJan 31, 2024Tutor
My Nighthawk app cannot access my R8000P. I don't know how to do what you are suggesting.
- plemansFeb 01, 2024Guru - Experienced User
You can't change to access point mode through the app. You'd have to log into the R8000P.
If you can't access it because its on a different subnet, disconnect the r8000p from the eero, connect a PC directly to the r8000p. then try accessing it using the browser. Once you switch it over to access point mode, it'll loose its IP address and need to be connected to the Eero to be assigned one as it won't be managing any dhcp/nat at that point
