JohnBecker
Jan 29, 2024Tutor
R8000P Nighthawk router not working with Eero Pro 6E
After trading-in my Zyxel modem with the Eero pro 6E, my R8000P Nighthawk router no longer works. My ISP is Altafiber and I'm using fiber optics. Cat 6 is my cable from my ONT. Any help would be ap...
- Feb 03, 2024Since the eero is managing DHCP, it'll have the address in it's attached devices page. Look that up in the eero and use it to access it
Feb 01, 2024Guru - Experienced User
You can't change to access point mode through the app. You'd have to log into the R8000P.
If you can't access it because its on a different subnet, disconnect the r8000p from the eero, connect a PC directly to the r8000p. then try accessing it using the browser. Once you switch it over to access point mode, it'll loose its IP address and need to be connected to the Eero to be assigned one as it won't be managing any dhcp/nat at that point
JohnBecker
Feb 03, 2024Tutor
Well, I have good news and bad news:
I "successfully" used www.routerlogin.net to change from router to AP mode.
The internet is working.
ONT to eero to Nighthawk.
However, I cannot access the Nighthawk. www.routerlogin.net takes me to a Netgear page.
Any thoughts on how to access the Nighthawk?
- plemansFeb 03, 2024Guru - Experienced UserSince the eero is managing DHCP, it'll have the address in it's attached devices page. Look that up in the eero and use it to access it
- JohnBeckerFeb 03, 2024Tutor
That worked!!!
Hey, thank you so much for working with me on this. You have been much appreciated.
Do the four ethernet ports on the back of the Nighthawk now serve as a hub? Switch? Or Something else?
And can I now use the Nighthawk for a dedicated 2.4 GHz wifi for example?
- plemansFeb 03, 2024Guru - Experienced UserHub/switch basically the same thing. It'll work just like it did before but it's not managing the routing features, the eero is.
You can set it as a dedicated 2.4ghz or leave it's smart connect on. Up to you - JohnBeckerFeb 03, 2024Tutor
Got it. Thank you again.
- FURRYe38Feb 05, 2024Guru - Experienced User
Enjoy. 📡
