Slyrr
Nov 30, 2021Aspirant
R8000P Nighthawk Router Throttles upload speed
I recently bought an R8000P Netgear router, replacing a nearly 10 year old router. I expected to get better performance, but the old router actually performed better. Here are the issues I am curre...
Dec 01, 2021Guru - Experienced User
- SlyrrDec 01, 2021Aspirant
The firmware version is v1.4.2.84. But again, I say that I have tried updating to the most recent firmware, and it has accomplished nothing. Upload speeds at my desktop computer are still nearly 70% lower than what they should be. I rolled it back because there are so many posts and complaints which say the new firmware causes more problems than it solves.
There is no 'modem', and therefore I cannot give you a model number for the modem. My internet is a fiber connection through Centracom. There is one network port in the house, a simple plug-in internet port that's in the wall. The router is plugged into the wall connection, and the other devices are connected to the router. The internet provider network port, and the wifi router, and the desktop computer, are all located in the same room. The router is therefore the source of the problem, given that the old router had NO such issues, and these problems did not manifest themselves until after I'd gotten the new router.
Should I return this router and buy another brand? I have seen many threads, posts, and compliaints about these newer Netgear routers, and none of the solutions that others have posted anywhere have done anything to resolve my issues.
There is no reason why this router should be strangling my upload speed, or refusing to connect me to any web pages until after I've refreshed them 2-4 times. It's incredibly frustrating and I wish I hadn't already gotten rid of the old router.- FURRYe38Dec 01, 2021Guru - Experienced User
I would also have powered OFF the ONT for 1 minute along with the router.
Try a different router then.
- michaelkenwardDec 01, 2021Guru - Experienced User
This is an odd setup that is hard to figure out.
In the past those "LAN socket" arrangements have sometimes proved to be connections to a router. So users and up with router piled on router.
Talk of a "fiber connection" is essentially meaningless. Show me an Internet service that does not have a fiber connection somewhere on the network.
It sometimes refers to an optical fibre to the premises. No modem there either, just something called an "OTN". But in your case, the Internet speed is so slow that it is hard to see how fibre can come anywhere within a mile of the property. The speeds you get, 51 Mbps down and 10.5 Mbps up, are more like DSL than fibre. True fibre can hit 1000 Mbps, sometimes even higher.
Unfortunately, I see no sign that anyone else here uses Centracom. (Where are you?) So there is not much in the way of background history to draw on.
Does it offer any advice on how to configure routers on its network? Is there a self support group for Centracom users? There may be some hidden tweak in the settings that could fix your problem.
Yes - I both rolled back the firmware, AND powered down at the same time, AND reset to factory settings. When I did that - the upload speed went to 10.5 mbps - but only for a couple of days. Then it went back down to 3.5 and has hovered there ever since. So it seems to only be a temporary fix. The blackhawk app keeps telling me my upload speed is 9.8 or thereabouts. But that's NOT what I'm getting on my desktop computer, where the Ookla netspeed test consistently comes up at 3.5 or lower for upload speed.
I find it hard to believe that nobody here has ever heard of a setup 'like' this before. It's quite common for internet service providers to rig a house so that there is one network/internet jack in the wall. Then you plug your router into that jack. Then you plug any devices into the router so that they're 'behind' it. That's where the whole jargon of 'behind the router' came from.
I called Centracom, and they confirmed that it's a fiber speed connection. However, the deal for our condo complex was to get a certain level of speed only. So it is not that our fiber optic connection isn't capable of faster speeds. It's just a matter of the amount of money the Homeowner Association was willing to pay the ISP for blanket condo complex coverage, vs. the amount of speed Centracom was willing to provide for the price.
Centracom (and my condo) are in Utah. They list Arrus as being the most compatible modem equipment, but I don't need a modem. I just want a reliable router to get all my devices (and desktop computer) 'behind', so they will have some security, and NOT throttle my upload speed, or refuse to let me view a website unless I hit the 'refresh' button multiple times.
If it's a hidden setting, I'm sure it's hidden very well. The people at Centracom seem just as befuddled by my specific questions as the people here at Netgear. The tech people are just reading pre-fabricated answers off of a screen, and since my questions don't fit anything on their lists, they don't know what to say. They've suggested going into the router settings page and 'changing the wireless channel', which I'll do later this evening. But it's not the wireless connection that seems to be throttling my speed - it's the wired connection from router to the desktop computer....
