ImAnAuSSie's avatar
ImAnAuSSie
R8000P Nighthawk X6 AC3200 Firmware Upgrade Issue
Hi.  I used the Netgear web based portal to upgrade my R8000P Nighthawk X6 AC3200.  When the upgrade completed the router would no longer start up.   It appears to be in a continuous seaching loop.
I have tried to reset the firmware to factory settings by pressing the reset for as long as 15-20 seconds.   Also under the light chnages to amber.  Pressing the reset for 3 seconds, as well as 7 seconds. Nothings works. Any suggestions
 I have downloaded the firmware and saved it on a USB.   Is there any way to load this without having access to the software?
Any help appreciated.
