ewoki's avatar
ewoki
R8000P Nighthawk X6S AC4000 - Unable connecting internet modem directly to WAN Port
I have a R8000P with the current firmware V1.4.1.24_1.2.20. If I put the 100Mbit ethernet cable from the internet modem of the internet provider into the WAN port of the R8000P, the connectivity ligh...
  • ewoki's avatar
    Oct 10, 2018
    The solution in my case was to change the LAN cable. Now I use a CAT5e cable and have 1Gbit connectivity directly to the router.
