lanny119
Nov 17, 2020Aspirant
R8000P Nighthawk X6S AC4000 Firmware Issue
My router right now is on V1.4.1.50. The latest firmware is 1.4.1.64. I tried manually updating it and the version number didn't change. I’ve reset it by pressing the button and set it up again. I’ve ...
michaelkenward
Dec 02, 2020Guru - Experienced User
drjameso wrote:
Router would not update, so I manually updated firmware to 1.4.1.64_1.3.25 from 1.4.1.50_1.3.10 and it stopped working.
Stopped working? Which of the many functions that the R8000P performs failed?
drjameso wrote:
returned to factory setting and restarted.
Did you try that with the new firmware?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
You can reduce the hassle of reconfiguring all those settings by creating a backup of your settings before you reset. Then if something is still broken after the reset, and the new firmware has not fixed it, you can restore the device to its pre-reset state.
You could even try restoring the settings even if the new firmware has fixed the problems, but be prepared for the restore to also bring back your problems.
jpiacente
Dec 12, 2020Tutor
I just got off the phone with support. Based on everything I have read on these forums, the upgrade from V1.4.1.50 is a known issue. They wanted to charge me to try and solve a 'known' issue. How does a company get away with this??
"You are outside of the 90 days support"
I purchased the device on July 1. I enabled auto update on the firmware. v1.4.1.64 has a knowledge base entry on the Netgear website on September 30. My device should have auto updated within the 90 days. But because I did not check it, shame on me? It is my fault that the auto update did not work and I did not check it? What standard household user would EVER check that?
I requested them to simply send me an RMA and I will return the device. They cannot do that unless they first troubleshoot. Fine, we can troubleshoot. I am ok with that. You will be charged for this. OK, I am NOT ok being charged to troubleshoot a known issue!
I requested to speak with a manager, after being put on hold for 5 minutes, I was told there were none available.
They will send me the manual update process to do myself and I can call back if it does not work.
My biggest issue? How many other people have bought these devices and just trust the Netgear? How many people are sitting out there thinking they are getting the security updates they need because they clicked 'auto update'? People whose kids or grandkids installed the router and are not there to check it for them?
Shame on Netgear during this time when no one is allowed to go to their parents/grandparents house to look at things like this.
- DRTheMightyJan 11, 2021Initiate
I am in this exact same situation. Did you ever resolve or did you send it back?
