CharlieOH
Apr 24, 2024Tutor
R8000P Nighthawk X6S gives no flashing power light during firmware upgrade process
Netgear R8000P Nighthawk X6S AC 4000 WiFi Router Firmware update of my R8000P using the GUI fails. When I try to use the TFTP client the instructions say to: 8. Turn your router off for 1...
- Apr 25, 2024
Shooties. The .50 version. Thats what I get for not asking at the start.
that one had issues where users weren't able to update firmware. For the longest time, they had to exchange them with netgear as the firmware caused a lock. A user found a way around it that you can read about here:
The standard tftp/nmrpflash won't work. You need the extra few steps to get it to work right.
Apr 25, 2024Guru - Experienced User
if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- michaelkenwardApr 25, 2024Guru - Experienced User
https://github.com/jclehner/nmrpflashYes.
And persevere with TFTP. It isn't easy.
This may help:
- plemansApr 25, 2024Guru - Experienced User
michaelkenward is correct. It can take several tries to get it to work right. I've had better luck with nmrpflash than tftp but I've used both successfully
- CharlieOHApr 25, 2024Tutor
The problem isn't that the power light is flashing. The problem is that it never flashes as the directions say it should. Please read my initial message carefully.
Kind of misses the point.
The power LED on your router is not as it should be. Different routers have different ways of showing that.
If TFTP doesn't get it flashing first time around, try again. And use Windows TFTP rather than the TFTPd64 mentioned in your first message.
In your case, there is another problem. Your first message says:
The power LED turns orange after power off and back on, but never flashes. It stays solid orange and then changes to solid blue, never having flashed.
Solid Blue doesn't seem to be a part of the repertoire for the R8000P. People have confused blue with white before now. If it is white, then the firmware may not be bust.
If it really is blue, then I'd try a different power supply. That's another possible cause of wonky power LEDs.
The nmrpflash looks very very challenging. I am not that sophisticated a user. If it requires the power light to flash as the other options do, I'm right back where I started anyway.
You're stuck anyway. You really can't mess it up more than it already is (sadly).
I'd try a few times. it looks daunting but isn't bad once you try it.
there's a youtube video that walks you through it. Worth a shot.
https://www.youtube.com/watch?v=qxQu3wtpFYo
