CharlieOH's avatar
Apr 24, 2024
R8000P Nighthawk X6S gives no flashing power light during firmware upgrade process
Netgear R8000P Nighthawk X6S AC 4000 WiFi Router   Firmware update of my R8000P using the GUI fails.  When I try to use the TFTP client the instructions say to:      8. Turn your router off for 1...
