alaknkstiyo
Sep 11, 2017Aspirant
R8000p QoS not showing up
Hi I've just upgraded from a x4 to a x6s, recently configured from scrath but I seem to be unable to find QoS and to be able to see which device is using all my bandwidth, do you guys know how to...
- Sep 15, 2017
Per engineering, QoS will be available in the fourth quarter.
ElaineM
Sep 13, 2017NETGEAR Employee Retired
Welcome to the community, alaknkstiyo
When you access admin page of the router, don't you see it under Advanced and then LAN Setup.
Under LAN Setup, you should be able to see QoS. I believe the router is using Dynamic QoS.
How do I enable Dynamic QoS on my Nighthawk router?
alaknkstiyo
Sep 13, 2017Aspirant
Hi Elaine
Thanks for replying, no QoS is shown even in advanced setup, I cannot even se the bandwidth usage when checking attached devices.
- alaknkstiyoSep 13, 2017Aspirant
- ElaineMSep 14, 2017NETGEAR Employee Retired
Thank you for the screenshots. Let me check this with our engineering team and get back to you as soon as I have an answer.
- alaknkstiyoSep 14, 2017Aspirant
I did a bit of research and seems WMM is QoS but it won't let me control the priority level of any device plus won't show the bandwidth used by any of them like in the old R7500
