thesun's avatar
thesun
R8000P renames my 5G access points to defaults with no security
I thought this was a one-time fluke but apparently, anytime my R8000P loses power or is turned off, it delightfully deletes the settings of my 5G wireless access points, returning them to the default name and with NO SECURITY.  Is this happening to others?  It's a show stopper, frankly, and if there's not an easy, quick, permanent fix this router is headed to the return bin.
Does anyone else have this issue?  If it's just that I somehow have a defective unit, that's good to know.
  • FURRYe38's avatar
    Do you have a backup saved with a good config set?
    • thesun's avatar
      thesun
      Hi, thanks for the reply.  It's the most up-to-date firmware, the V1.4.2.84.  I'm not going to list the modem, as I don't believe this would be anything but a router-specific issue.  As far as a backup, you mean to manually backup the system onto my computer and then restore it each time?  If that turns out to be the workaround, that's again, a show-stopper.  I'm kind of appalled that a $300 dollar router would be this buggy and there'd be so little I can do about it.
      • FURRYe38's avatar
        Modem information would be helpful as it could also be a factor.
        Also a valid troubleshooting step as well. Helps us get a better idea of the configuration as to better help you.
        If not, you'll need to open a support ticket with NG support and let them know what your seeing.
        Good Luck.
