ArdithPBrown
May 02, 2022Aspirant
R8000P router disconnecting on laptop
Hello, I have recently bought a new R8000P router it keep disconnecting on my laptop once it is connected it disconnects again and again. I don't know what to do
May 02, 2022Guru - Experienced User
Be sure the laptops wifi and ethernet adapter drivers are up to date.
Is Smart Connect, Beamforming, MIMO and 40Mhz only enabled?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- ArdithPBrownMay 02, 2022Aspirant
Firmware Version 1.0.4.120 is currently loading, I already updated the Ethernet adapter drivers on my laptop but I'm still facing this issue.
- FURRYe38May 02, 2022Guru - Experienced User
