ArdithPBrown
May 02, 2022Aspirant
R8000P router disconnecting on laptop
Hello, I have recently bought a new R8000P router it keep disconnecting on my laptop once it is connected it disconnects again and again. I don't know what to do
ArdithPBrown
Firmware Version 1.0.4.120 is currently loading, I already updated the Ethernet adapter drivers on my laptop but I'm still facing this issue.
May 02, 2022Guru - Experienced User
Is Smart Connect, Beamforming, MIMO and 40Mhz only enabled?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
