Scorpio123
Nov 04, 2021Apprentice
R8000P seemingly random lock ups.
This problem happens at random intervals (about a week +) so difficult to track. After manually upgrading the firmware to version "1.4.1.82_1.3.40_hotfix" the router occasionally locked up - all ...
Nov 04, 2021Guru - Experienced User
I don't have that model to test but it seems like the last 2 versions of firmware for it have caused issues.
Its lately been DNS issues. I haven't seen a whole lot of locking up issues.
If your current version stays stable, great. If it doesn't, did you try a factory reset in any of your firmware changes?
Scorpio123
No I haven't yet tried the factory reset option in any of the FW changes. I'll give this FW a few days longer to try to validate the hardware and if OK then try reflashing the latest FW and do the factory reset. The later updates seem to have security patches so would like to update when possible.
Thanks.
John.
P.S. Do you know if it is valid to 'backup settings', do a factory reset and the restore settings or is this just as likely to cause problems as not doing a factory reset?
- plemansNov 04, 2021Guru - Experienced User
OK, thanks for keeping us updated :)
- Scorpio123Nov 04, 2021Apprentice
Sorry updated my reply and then saw you had already responded.
John.
If you have a lot of customizations, for sure. take a backup configuration and reset/reinstall with it. If you still have the issues, then try without the backup. it doesn't hurt to try.
Or you can reset and try it in its default configuration. If it stay stable in the default but not when your backup is running, then you know its something in the old settings causing issues.
