Scorpio123
Nov 04, 2021Apprentice
R8000P seemingly random lock ups.
This problem happens at random intervals (about a week +) so difficult to track. After manually upgrading the firmware to version "1.4.1.82_1.3.40_hotfix" the router occasionally locked up - all ...
Scorpio123
No I haven't yet tried the factory reset option in any of the FW changes. I'll give this FW a few days longer to try to validate the hardware and if OK then try reflashing the latest FW and do the factory reset. The later updates seem to have security patches so would like to update when possible.
Thanks.
John.
P.S. Do you know if it is valid to 'backup settings', do a factory reset and the restore settings or is this just as likely to cause problems as not doing a factory reset?
Nov 04, 2021Guru - Experienced User
OK, thanks for keeping us updated :)
- Scorpio123Nov 04, 2021Apprentice
Sorry updated my reply and then saw you had already responded.
John.
- plemansNov 04, 2021Guru - Experienced User
If you have a lot of customizations, for sure. take a backup configuration and reset/reinstall with it. If you still have the issues, then try without the backup. it doesn't hurt to try.
Or you can reset and try it in its default configuration. If it stay stable in the default but not when your backup is running, then you know its something in the old settings causing issues.
- Scorpio123Nov 25, 2021Apprentice
On 10th November updated firmware to latest version again (V1.4.2.84_1.3.42) but this time did do a factory reset after upgrading.
Now 15 days later and it has not locked up yet ....... fingers crossed.
John.
