Scorpio123
Nov 04, 2021Apprentice
R8000P seemingly random lock ups.
This problem happens at random intervals (about a week +) so difficult to track. After manually upgrading the firmware to version "1.4.1.82_1.3.40_hotfix" the router occasionally locked up - all ...
Scorpio123
Jan 12, 2022Apprentice
FURRYe38 wrote:Would be curious to see if you put a laptop cooler fan under the router, if it would continue to lock up.
Was this version a good stable version or did it also exhibit this lock up? 1.4.1.66_1.3.26
Scorpio123 wrote:This problem happens at random intervals (about a week +) so difficult to track.
After manually upgrading the firmware to version "1.4.1.82_1.3.40_hotfix" the router occasionally locked up - all LEDS on front panel were fixed (not flickering) and not possible to connect via ethernet or wifi - nothing on the network on 192.168.1.1
After repowering the device started working again.
After second lockup there was a new firmware available so I upgraded to that 1.4.2.84_1.3.42
However, the R8000P has again locked up as above. Particularly annoying this time as it happened just as I was away from home for over a week and unable to connect to my Ring doorbell and cameras.
On return I repowered and it worked OK again.
This time I downgraded the firmware to a version which I had never had an issue with - 1.4.1.66_1.3.26
This was done on 1st Novemeber (3 days ago) and so far working OK but don't know if this will last.
Anyone else had similar issues?
John.
History. AFAIR.
When I first got an R8000P, it was set to autoupdate and updated itself to V1.4.1.50. I had a problem with this (and from various other comments so did a lot of other people) in that it would not allow any further upgrades or downgrades of FW. After a lot of tooing and froing, Netgear RMAed the router under warranty with the R8000P I have now.
I think it came with FW 1.4.1.64. and I set it to not autoupdate.
I then went to 1.4.1.66, 1.4.1.68 and interim 1.4.1.82 hotfix which caused issues.
I then downgraded to 1.4.1.66.
I do not know how much of the issues was made worse by me not doing a factory reset after upgrading.
When a new release came out I upgraded to1.4.1.84 which it is currently on and included a factory reset.
I suffer from random lockups but also random reboots - I only really know when the reboots happen if I am looking at the box and see the LEDs go out.as the reboot sequence goes through quite quickly.
The lockups happen randomly and usually after a long period so it is always difficult to know if the problem is fixed or not.
I am going to try again downgrading to 1.4.1 66 and I will see if I locate my laptop cooler to try. Do you ask this question because you have experienced overheating causing issues yourself with these routers? The R8000P is mildly warm underneath but not as hot as my previous TPLink router which you could fry eggs on and had yellowing of the plastic case from the heat.
However I don't know how long to leave it at 1.4.1.66 to know if the problem is fixed or not because of the randmness of the failures. I assume the FW updates are done for good reasons so don't want to leave myself open to a security issue.
Jan 13, 2022Guru - Experienced User
Let us know if it still happens with v66 loaded. Was there any other problems seen with v66 loaded prior or did it seem to work well for you?
I would loade FW and reset and start a fresh setup from scratch.
- Scorpio123Jan 18, 2022Apprentice
I have reverted to FW V66 and full factory reset. To avoid too many variables I am not going to apply cooling at this time.
I do not know of any problems with V66. It never locked up but I do not know if it randomly reset as this is hard to spot.
FURRYe38 wrote:Let us know if it still happens with v66 loaded. Was there any other problems seen with v66 loaded prior or did it seem to work well for you?
- Scorpio123Jan 20, 2022Apprentice
This should now really be relabelled from 'seemingly lock ups' to 'intermittent no response from router / lack of connectivity'
I found I was unable to connect again today either via ethernet or wifi.
However rather than just reboot I tried a few things.
So now on FW66.
All LEDs active on the front. - network ones flickering - except for 5GHz -1 which is OFF.
Everything else solid including Internet.
Unplugging / plugging devices into the ethernet ports - the 'link' LEDs go out and come back on again.
The wifi button LED will not go out when held in - i.e. unresponsive.
Trying to connect via Wifi - gets an unable to connect error.
Trying to connect via Ethernet - gets an unknown network and no DHCP assigned IP address .
Perhaps the working LED functions happen at a hardware level so continue to function but the CPU of the device is not reponding.
Again rebooting returns operation to normal.
I now can't see how this can be FW related - I think it must be hardware. If I can find the fan I will try cooling - notr really ideal or reliable solution but may prove a point..
It is now out of warranty so I am stuffed. I may try opening it up to check for obvious problems (dried out caps, dry joints, signs of overheating etc) - [I am an engineer so I do know what I am doing :-) ]
I had got as far as looking at a replacement wifi router on Amazon (it's in my basket) and thought 'no - I have to take a look' inside.
I disassembled the unit and in manufacturers usual friendly way they hid one screw under the rear label so I had to make a hole in it to unscrew. The cover then slides off revealing the PCB with the antennae connections to it.
The PSU has all the nasty mains bits in it - before the health and safety critics pipe up about the dangers of opening up equipment :-)
It also must have all the power supply smoothing in it as there seem to be no signs of electrolytic capacitors on the PCB.
The board has a very large heatsink mounted on it attached by three soldered pillars to the main PCB.
There appear to be four 'devices' under the heatsink - 3 CPUs or processors of some sort and a networking module?.
I discovered on the rear of the PCB across various components near to these devices a grey substance (contaminant)
I am not sure what it is but it looks like solder paste!!This 'could' have been making intermittent connections across the components - could this have caused my issues??
(I once had a problem with my oscilloscope which after 15 years of use suddenly lost one channel - intermittent no output) After a very long investigation I found a thin sliver of solder which had been sticking vertically up and over the years gradually bent over until it was shorting out the input FET)I have removed the contaminant using a toothbrush and plenty of Isopropyl Alcohol.
The unit is now reassembled and reconnected so will now monitor it.
I will try to upload some photos of the board (if possible) showing the substance across the components.
