Evilbeefstick
May 19, 2021Aspirant
R8000p slow speed lost connections
I purchased the router in September of last year and have not had any complaints. The past two days I have had a bunch of issues though. I have download speeds up to 1200 mbps from my provider and pre...
May 20, 2021Guru - Experienced User
What modem/gateway are you connected to?
You're firmware isn't the best one. the R8000P got the netgear armor update. Not all played nicely with it. the newer version have helped some. the current one is 1.4.1.68.
Try installing that and then doing a factory reset, reinstall. Don't use a backup configuration.
If that doesn't help, try version 1.4.1.42. It was the version prior to netgear armor. Sometimes it help. If it does, disable auto-updates.
Evilbeefstick
May 20, 2021Aspirant
Modem is a CM1200-100NAS
Router will not take an update I have tried via the App, Netgear Genie, and through uploading the file. Everytime is says update failed. On routerlogin.net is says connewction interuped. I am doing this on a pc that is wired in.
