arnermd
Sep 08, 2021Initiate
R8000P stuck on firmware version V1.4.1.50_1.3.10.
Yet another router stuck on firmware version V1.4.1.50_1.3.10. After countless hours searching and trying fixes, I called the help line and they want me to pay to extend my support, for an issue tha...
Sep 08, 2021Guru - Experienced User
What do you mean by stuck FW?
arnermd
I mean the firmware will not update to newer revisions.
I go to the router IP address, it says a firmware update is available, I click on it and it says it has found a new version, I click yes (update), the firmware appears to download and install, router restarts, firmware version is still listed as V1.4.1.50_1.3.10.
I have also tried a "maunal" update, download newer (or older) firmware version, extract it on my hard drive, on the router update screen I direct it to the .chk file and click update, it appears to install, router reboots and reports fimware version V1.4.1.50_1.3.10.
Also tried a factory reset, no success.
Several people on this board have suggested this version of firmware has a bug which prevents it from updating itself.... I am inclined to think they are correct as it matches my experience.
What is most frustrating is I have yet to see any acknowledgment from Netgear that this problem exists. A good company would respond something like "oh yeah we know about that problem, we are sorry, here is what we are going to do to make it right....."
When I call Netgear I get "Problem? What problem, everything seems fine, but just in case... you should buy some more phone tech support, then maybe we will tell you what the real problem is..."
I am now an ex Netgear customer..... phenomenal waste of my time....
