JeffMcL
Jan 22, 2021Guide
R8000P Unable to download GUI language file from Netgear server
Have tried multiple time to upgrade my firmware, both manually and through the browser. Neither works. Please help!
michaelkenward
Jan 23, 2021Guru - Experienced User
Start by telling us what the current firmware is and what version you want to install.
Then tell us what happens when you try the update.
I'm afraid that "Neither works" is a bit thin on diagnostic details.
I assume that you are following these instructions:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- JeffMcLJan 23, 2021Guide
Current GUI Language Version: 1.4.1.64_2.1.46.1 New GUI Language Version: 1.4.1.66_2.1.46.1 Current Firmware Version 1.4.1.50 New Firmware Version 1.4.1.68_1.3.28 - michaelkenwardJan 23, 2021Guru - Experienced User
- tfournie89Jan 23, 2021TutorI am having this same problem as OP. Has there been a resolution to this issue?
When I followed the instructions you linked, it did do a full reboot but didn’t upgrade the firmware.
