JeffMcL
Jan 22, 2021Guide
R8000P Unable to download GUI language file from Netgear server
Have tried multiple time to upgrade my firmware, both manually and through the browser. Neither works. Please help!
JeffMcL
Jan 23, 2021Guide
| Current GUI Language Version: | 1.4.1.64_2.1.46.1 |
| New GUI Language Version: | 1.4.1.66_2.1.46.1 |
| Current Firmware Version | 1.4.1.50 |
| New Firmware Version | 1.4.1.68_1.3.28 |
michaelkenward
Jan 23, 2021Guru - Experienced User
I assume that you are following these instructions:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- tfournie89Jan 23, 2021TutorI am having this same problem as OP. Has there been a resolution to this issue?
When I followed the instructions you linked, it did do a full reboot but didn’t upgrade the firmware.- JeffMcLJan 24, 2021Guide
The message I get is:
I know how to manually update the router and it "goes through the motions" and reboots but does not actually update the firmware.
- JeffMcLJan 27, 2021Guide
This is rediculas. Is there NO solution to this issue that a lot of people seem to have??? I does not matter if you attempt to upgrade through "automatically" or manually.
