R8000PFixer's avatar
R8000PFixer
Initiate
Dec 09, 2021
R8000P V1.4.1.50 Update workaround
Hello All Infuriated R8000P Owners,   Ok I found out a solution to the V1.4.1.50 "Lock-Down" as I call it.  I too was not able to install updates through, Automatic Update, Manual Update Upload, or...
  • Shoestar's avatar
    Shoestar
    Dec 28, 2021
    HOLY SMOKES!!!!!!!!!!! THIS ACTUALLY WORKS!!!
    For me, the timings were completely different than what you said.
    Here are the steps that I took that worked for me:
    • Turn off the router
    • Execute the code "nmrpflash.exe -i PORT -f .0.chk"
    • Turn on the Router
    • Once the Orange light comes on, press the Reset button
    • The upload should do its thing.
