R8000PFixer
Dec 09, 2021Initiate
R8000P V1.4.1.50 Update workaround
Hello All Infuriated R8000P Owners, Ok I found out a solution to the V1.4.1.50 "Lock-Down" as I call it. I too was not able to install updates through, Automatic Update, Manual Update Upload, or...
- Dec 28, 2021
HOLY SMOKES!!!!!!!!!!! THIS ACTUALLY WORKS!!!
For me, the timings were completely different than what you said.
Here are the steps that I took that worked for me:
- Turn off the router
- Execute the code "nmrpflash.exe -i PORT -f .0.chk"
- Turn on the Router
- Once the Orange light comes on, press the Reset button
- The upload should do its thing.
Oskitou
Jan 03, 2022Aspirant
Thank you, thank you, thank you!
I gave up on gettting this sorted out by Netgear long time ago (awful customer service), then stumbled upon your post by chance!
R8000PFixer ,Your solution is far from simple, but it does the job. So happy to see V1.4.1.50_1.3.10 gone from my screen! :)
