unlisted
Apr 14, 2024Aspirant
R8000P vulnerabilities http_basic_auth, weak_password
AT&T give me the message below; is AT&T correct? If so, can the R8000P be fixed? Device R8000P Description There were 2 vulnerabilities found on your R8000P. The vulnerabilities are htt...
michaelkenward
Apr 14, 2024Guru - Experienced User
Which bit of AT&T gave you that message?
Then the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- unlistedApr 14, 2024AspirantGreat questions and the answers are the usual in part and atypical in part. Firmware is latest as of this post, and if Netgear releases revised new firmware then I will probably allow it to be installed. ATT-T's scanning software is ATT default (i.e., included not extra each month) ActiveArmor software. Netgear hardware is configured as access point (i.e., dhcp server disabled). I am curious about what exactly AT&T is identifying.
- michaelkenwardApr 14, 2024Guru - Experienced User
unlisted wrote:
Firmware is latest as of this post, and if Netgear releases revised new firmware then I will probably allow it to be installed.There is a clue in there as to why claims of "latest" are not much help.
If you rely on "allow it to be installed" there is a risk that it is not the latest. Only the version number tells us what is really going on at your end.
Apps and the GUI interface are famously good it missing updates. People making those claims can be years out of date.
ATT-T's scanning software is ATT default (i.e., included not extra each month) ActiveArmor software. Netgear hardware is configured as access point (i.e., dhcp server disabled). I am curious about what exactly AT&T is identifying.There's a lot going on in there, apart from knowing nothing about what you mean by "ATT default". All of it open to misunderstanding.
For example, access point is not the same thing as "dhcp server disabled", in the same way that people turn up here thinking that turning off the wireless disables a router.
The people who respond to problems that arrive here have seen hundreds of messages. They are familiar with the common issues that can gum up a network. Their questions are based on dealing with those problems. If they don't get clear answers they may more on to the next fresh message.
As to your question, ask AT&T. It should know all about the false positives that it can create.
- unlistedApr 14, 2024AspirantIt does make for an interesting challenge for the gurus, doesn't it? The post contains all the information that AT&T provides.
