netoperator's avatar
netoperator
R8000P Where do I download the software
Where do I download the software for R8000P  Nighthawk X65 AC 4000 Tri Band Wifi Router ?
1 Reply
  • > Where do I download the software for R8000P [...]
       If you mean the router firmware, then...
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  (For older versions, under Firmware and Software
    Downloads, look for "View Previous Versions".)  Find the kit(s).
    Download the kit(s) you want.  Read the "Release Notes" file for
    instructions.  (In the User Manual, look for "firmware", and,
    especially, for a topic like "Manually Upload Firmware to the Router".)
    When that fails because of a deficient User Manual, try:
          https://kb.netgear.com/23960
