k1ttt's avatar
k1ttt
r8000p why would lan connections break when wan fails?
On my r8000p i have wired connections to my windoze server that runs dns, dhcp, web services, file shares, etc.  On WiFi i have both windoze and i-thingy clients.  When my WAN connection goes down the machines on the LAN suddenly can't connect to each other, and actually lose active connections(even ones with machines that have static addresses) so i can't really blame a server dns or dhcp problem.  Why would dropping a WAN connection cause the LAN to misbehave like that???
  • michaelkenward's avatar
    michaelkenward
    It shouldn't. So some more details might be useful.
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    • k1ttt's avatar
      k1ttt
      Firmware Version  V1.4.4.94_1.3.56
      the wan configuration is like this... which took spectrum a week to figure out and configure properly as we are their first home fiber installation town, and i am their first small business' account on that system... I have a static IP which is assigned to the r8000p, with ip = x.x.x.190, netmask=255.255.255.252, gateway x.x.x.189.  the internet port of the r8000p goes to a spectrum router gateway with the x.x.x.189 ip which then goes to their fiber modem which is a brand new gb capable box that they upgraded me to when the old one had some kind of intermittent problem.  only 1 port on the spectrum router is used, the one to my r8000p, the wifi ports are disabled as are all it's services like dhcp, etc, as far as i can tell their router is just passing through everything going and coming to my router, i tried to get more detail from spectrum about it but apparently only one person somewhere in their engineering group could even figure out how to provision it.   i could get numbers off them but don't know if they are spectrum part numbers or something else so they may not be that useful.  on the r8000p the dhcp, dns, guest lan, and lots of other stuff is disabled, i do dhcp and dns from my server on the lan, the r8000p does do nat for several incoming services used for ham radio stuff.
      the real confusing part for me is that the server has static ip's for its network ports, 192.168.0.2 and .3, as do many of the single purpose windoze machines on wifi or ethernet ports and they all lose connections... or well maybe the wired ones might stay connected to the server, there are 2 special purpose machines on the lan that are wired ethernet to the router along with the server, they might still work but the only thing they connect to are outside addresses so they die anyway if the wan goes down... but all the wifi connected stuff is left stranded and can't even connect to the server, and they even lose active existing connections to the server which is really annoying!
        michaelkenward
        Heaven only knows what that network configuration is all about. I don't. It seems to be a recipe for chaos.
        What is the reason for those "static" IPs. That term gets widely abused and  misunderstood.
        Do you mean that the ISP has given you a fixed (WAN) IP address on the Internet. Or are you talking about IP addresses on your local network.
        More important, the other question I asked, what is the modem/router in between the R8000P and the internet?
        Perhaps they didn't understand your question. But I am suspicious about the "as far as i can tell " bit.
        Look at whatever label is on their router. If it really is a router, then you hit the first wall that catches many people out.
        Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
        This explains some of the other drawbacks.
        What is Double NAT? | Answer | NETGEAR Support
        Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
        It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. But some Internet service providers, such as BT in the UK, supply modem/routers that won't work in bridge mode. There may be ways to get the modem/router to cooperate. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
        Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
