Brian10121
Mar 04, 2022Tutor
R8000P WiFi capping at <25 mbps on all 3 supported channels 2.4/5g/5g2
I'm capping at <25mbps on 2.4, 5g, and 5g2. These are the speeds while testing directly next to the router on several different devices. I am at a loss here as i've changed channels etc. in attempts ...
- Mar 04, 2022
Glad it fixed it!
Again, sometimes old settings carried through firmware upgrades can cause issues.
Either way, glad it worked.
If you mark it solved, it keeps others from trying to fix your issue still. :)
A backup is always a good thing to make now that its working well :)
Brian10121
Mar 04, 2022Tutor
Factory reset fixed it, however looking at all the settings they are the same (shrugs)
Mar 04, 2022Guru - Experienced User
Glad it fixed it!
