ozdan's avatar
ozdan
Guide
Apr 13, 2021
R8000P WiFi dead
I'm dealing with my second (third actually- second was brick that Netgear replaced) R8000P and it has been quite a challenge. I bought my second router back in August of 2020 to help extend WiFi to t...
  • ozdan's avatar
    ozdan
    May 01, 2021
    Ok, I figured it out. Since the AP mode router worked after I disabled the wireless on the main router via the setup process I looked to see what settings were in place. The only difference was the that the AP mode router was set up to as a DHCP server with a range of .2 - .254, gobbling up all of the IPs, so the main router could not serve up any. Since the AP mode router got .28 from during the setup, I alloted it .29 - .254 and the primary has .2 - .27. Now both routers have the same SSID and there's a slightly weak signal inbetween routers.
    Did Netgear advanced support bother to give me this crucial bit of information regarding DHCP allocations? No, which further leads me to believe that they want to cash in on selling their premium support.
