petr2020
Aug 11, 2022Aspirant
R8000P WIFI disconnects even with latest firmware
R8000P WIFI disconnects even with latest firmware V1.4.3.88_1.3.50. I have to reboot the router. This was happening once a week and now it is happening every day. I see old posts on this subject b...
- Aug 20, 2022
Sometimes thats all that it takes. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
michaelkenward
Aug 12, 2022Guru - Experienced User
Not much to go on there.
Does the wifi go off? SSIDs disappear? What do the LEDs look like?
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
