petr2020
Aug 11, 2022Aspirant
R8000P WIFI disconnects even with latest firmware
R8000P WIFI disconnects even with latest firmware V1.4.3.88_1.3.50. I have to reboot the router. This was happening once a week and now it is happening every day. I see old posts on this subject b...
- Aug 20, 2022
Sometimes thats all that it takes. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
petr2020
Aug 19, 2022Aspirant
I was able to factory reset the router and rebuild it and just set up one SiD for all channels. I have not had to reboot router for over a week now!
Aug 20, 2022Guru - Experienced User
Enjoy. 📡
