fouadhallal
Aug 19, 2024Aspirant
R8000P wifi speeds
I noticed recently that Wifi speeds goes down every couple of days. Instead of getting about 500mbps, I get about 40mbps. I reboot the router from the App. After reboot, I get the high speed. Ir ...
Aug 20, 2024Guru - Experienced User
are you using smart connect?
If so, your device might be connecting to the 2.4ghz and not the 5ghz. 2.4ghz is a lot slower. That 40mbps is more along the lines of what you'd get.
fouadhallal
Aug 20, 2024Aspirant
Thank you for your response.
Is smart connect a setting on the router?
The thing is, after I reboot the router, the same device get more than 300mbps. It then degrades after a day or so
I checked other solutions and they recommended specifying certain channels for the wifi, which I did. That didn't help my issue at all.
- plemansAug 20, 2024Guru - Experienced User
Smart connect allows devices to switch between the 2.4ghz and 2x 5ghxz channels as needed.
What is Smart Connect and how do I enable or disable it on my NETGEAR router? - NETGEAR Support
It could be the device dropping down to the 2.4ghz connection
