RahulM's avatar
RahulM
R8000p WPA2 Personal android issue
Hi
I have a very strange issue. I have R8000P router. Two android phone. One is redmi note 7 pro. If I use 1.4.1.30 firmware I am able to connect as WPA2 Personal on redmi note 7 pro. But if I upgrade it to latest firmware 1.4.4.94 Wifi do not connect. I have to convert WIFI as WPA-PSK [TKIP] + WPA2-PSK [AES] to connect to redmi note 7 pro.
The only difference it seems is Armor was introduced after 1.4.1.30 this firmware.
I tried enabling armor trial but it is showing failed to activate. I am not using Smart Connect. (Smart connect has the same issue).
