Joshmarshall123
Nov 15, 2022Guide
R8000P Xbox Constant Connection Issues
Ever since I switched to this router my Xbox series x has been having issues. I’ll click on an app and it will say something along the lines of “not connected to network” even though it is. I’ve trie...
- Nov 16, 2022
Do you have IPv6 enabled? If not, try enabling it.
Nov 16, 2022Guru - Experienced User
Joshmarshall123
Nov 17, 2022Guide
So far it seems like turning on IPv6 auto has fixed my issues. Will report back if anything changes. Thanks!
- plemansNov 17, 2022Guru - Experienced User
Glad it worked! you might mark it solved so others aren't still trying to fix it. (and a backup doesn't hurt)
