Joshmarshall123
Nov 15, 2022Guide
R8000P Xbox Constant Connection Issues
Ever since I switched to this router my Xbox series x has been having issues. I’ll click on an app and it will say something along the lines of “not connected to network” even though it is. I’ve trie...
- Nov 16, 2022
Do you have IPv6 enabled? If not, try enabling it.
Joshmarshall123
Nov 17, 2022Guide
So far it seems like turning on IPv6 auto has fixed my issues. Will report back if anything changes. Thanks!
Nov 17, 2022Guru - Experienced User
Glad it worked! you might mark it solved so others aren't still trying to fix it. (and a backup doesn't hurt)
