TonyRowlson
Feb 05, 2019Aspirant
R8300 - Desktop WiFi Constantly Disconnects w/ "The default gateway is not available"
First post and I'm going absolutely insane trying to figure this one out. I've currently got an R8300 Nighthawk X8 AC5000 Smart WiFi Router. All my other devices 2.4 or 5 GHz maintain a steady wirele...
- Feb 11, 2019
So I wanted to follow-up. I had continued researching and troubleshooting. Update drivers/chipsets, etc but still no luck. However, I came across something the other day that I believe may have done the trick oddly enough and I wanted to post it here in case someone else runs into a similar issue as it may solve a headache for them.
I went into Device Manager under Network adapters and clicked on "Update Driver Software..." but instead of searching automatically for the driver, I clicked "Browse my computer for driver software" and then clicked "Let me pick from a list of available drivers on my computer". I de-selected "Show compatible hardware", I selected "Intel" for the Manufacturer and selected the "Intel(R) Dual Band Wireless-AC 7260 (Microsoft)" instead of the (Intel) one. So far it's been 48 hours without any disconnects. So the Driver Date is now 22-Feb-2015, Driver Version 17.15.0.15, Provided by Microsoft and Digital Signer: Microsoft Windows. Funny how rolling it back to the original install didn't work but the end-state solution still involved rolling back to an older driver provided by someone other than the manufacturer.
TonyRowlson
Feb 06, 2019Aspirant
michaelkenward ,
Thinking it was a potential Windows issue with no previous luck resolving is exactly why I decided to try a clean install. I used a Tier I ISO of Windows 10 - Pro v1803 (dated Aug 2018) from MSDN. However, during the setup process of selecting my WiFi network and almost immediately after getting to the desktop for the first time, the problem started again. So I pretty much eliminated any extra applications, the Netgear Genie app, Antivirus (except Windows Defender), etc.. I've also got a laptop directly next to the desktop at the moment that is running Windows 10 - Home using WiFi flawlessly. So not sure if it is a Pro vs Home issue or what.
In regards to your comments, I'm sure I may have missed a few details but under the Network Profile for the WiFi network, it is currently set as a Private network, Metered Connection Off, and IP setttings are back to DHCP. The desktop machine does have an RJ45 Ethernet port plus I also have a USB-to-Ethernet dongle. However, the problem is that I'm physically separated by the router by more than 50' and that's the longest CAT5 cable I have. Worst comes to worst I can just disconnect about everything and move it within the physical distance but was really trying to avoid it.
IrvSp ,
In regards to the information, I'm assuming by "correct" you're simply asking if those are actually the settings/information and maybe not a typo. I've attached a compiled screenshot for clarification. With the exception of the Wireless mode, those settings are correct. The wireless mode change was simply done as an additional step as I saw another post saying that their issue was resolved by changing the wireless band to reflect g only and it fixed it for them. I had no such luck and reverted it back to "6. Dual Band 802.11a/b/g". There's 2 wireless modes though: an option for a/b/g (currently set at option 6. Dual Band 802.11a/b/g") and an option for n/ac (currently set at 802.11ac). The Intel article about recommended settings matches the current state of my adapter properties.
I've looked at the various Google articles and it definitely seems like a rampant issue across various OS and computer models. The most common responses seems to be checking for updated drivers or uninstalling/reinstalling them which I've already done.
Thank you both for taking the time to help look into this.
IrvSp
Feb 06, 2019Master
TonyRowlson, dropped another important nugget here... "I'm physically separated by the router by more than 50' and that's the longest CAT5 cable I have. ". You are pushing your luck with that, especially with 5Ghz. Articles like this state 150Ft inside, but that is line of sight. It further states it can be 25% or less with obstructions in walls. 5Ghz doesn't do as well as 2.4Ghz either.
Some routers do have beam forming settings and that can help some. Personally, I'm at about a 65 foot limit in my house. Router (r8000 as well as the old R7000) has a hard time connecting to some devices at the far end of the house and some outside locations. iPad's and phones have the hardest time due to the low number of Antennea's they have.
You might be better off looking for Power LIne Adapters to spread the signal.
- TonyRowlsonFeb 06, 2019Aspirant
IrvSp I probably should have clarified. I would need about a 60' of cable to go around corners, hallways, etc.. The desktop and the router are spacially about 25' apart with 1 interior (non-brick) wall separating them. All of my devices I use in this particular area have no issues connecting and maintaining a connection except for the desktop.
michaelkenward The desktop is a Dell XPS 8700. I'll do some more digging double-checking chipsets and current driver states.
Let me know if you all can think of anything else. The problem didn't start until I got the new router which is the reason I was thinking it had to be something router-related.
- michaelkenwardFeb 06, 2019Guru - Experienced User
The lapsed scientists in me says that you are spot on there.
But a new router can create a network that looks very different to Windows. So that has to come into the picture.
- IrvSpFeb 06, 2019Master
Boy are you hitting home here. I'm on a Dell XPR 8700 (almost 5 years old) and wife is on a Dell XPS 8500, I'm running W10 Home, she's on W10 Pro, both at the at the same version, V1809.
We've HAD problems with the supplied Dell Network Wireless Adapter. They usually supply the Dell one. Garbage it seemed... Since her PC is older we tried using the Dell wireless with her PC (or had to snake cables like you had to). Dell swapped it out for an Intel one too, and that really was just as bad. So I wired it, looked messy and bought a NG A6200 and never looked back. My 8700, I tried the Dell wireless, no good so I laid cable around the room. Both of us were 'happy'. Got the R8000, and it worked well and I could put all AC devices on one back for top performance. I bought a 'cheap' AC USB wireless adapter. Mistake, I couldn't even boot the Dell reliably. Had to do with the BIOS initializing the device in time to go on, but 20% of the time the device didn't respond fast enough and the XPS hung with the spinning dots. After a power off/on it ALWAYS worked fine. I did occasionally have problems coming out of sleep. Vendor bent over backwards. Offered to exchange the device, but I didn't think it was the device. After a few weeks of messing with it I decided to try wife's 8500. Never had a boot problem so I now have her A6200 and I'm happy. Yes, every one in a rare while it too doesn't come back from sleep immediately but that is minor.
She's had some problems with the USB I put on her PC. I've got some drivers for it of differing vintages. RealTek made the chipset and the vendor is having NO LUCK getting answer from them. Eventually the vendor did get an updated driver with a lower firmware number. I tried that and it the past 3 days, NO COMPLAINTS from my wife.
I seriously doubt your problem is with the router or Windows... unless you consider the driver the problem. Also that cards burried in the PC can see more interference that a device with an External Antennea. AC USB Wireless devices are reasonable it seems. $30 to $70 and in most cases you can just buy it, doesn't work, return it easily with NO STOCKING fees from some places.
Router change can mean a lot of differences, signal strength and footprint, channels used, number of antennea's, as well as internal differencse on processing TCP/IP packets.
I'd suggest getting ACRYLIC and using it to check the power level the 8700 has and IF it fluctuates, especially if you lose the connection, as it just used the wireless adapter to 'see' and doesn't need a connection. You might even be on a Congested channel, which you can then change.
- TonyRowlsonFeb 11, 2019Aspirant
