AlbertShym
Jan 17, 2018Guide
R8300 - Support for MD5 Certificates with Built-In VPN
OpenVPN has announced that they will be ending support for MD5 certificates in April of 2018. If that means that I will not be able to use the VPN feature of my router, I am wondering if there will b...
- Jan 28, 2018
Hi AlbertShym,
I am sorry for the confusion. What I meant was the NETGEAR will be supporting the new certificate that OpenVPN uses before it stops supporting the MD5 certificate.
JamesGL
Jan 21, 2018NETGEAR Employee Retired
Hi AlbertShym,
NETGEAR will support MD5 certificates for OpenVPN. It will be release before April of 2018.
- AlbertShymJan 25, 2018GuideBut since NETGEAR's VPN solution uses MD5 certificates, will NETGEAR update the VPN solution to use more secure certificates?
- JamesGLJan 28, 2018NETGEAR Employee Retired
Hi AlbertShym,
- AlbertShymJan 28, 2018GuideI see now. Thanks!
- JamesGLJan 30, 2018NETGEAR Employee Retired
Hi AlbertShym,
You are welcome.
- madbrainFeb 07, 2018Luminary
What's the schedule for the new firmware udpate ? I'm facing the same issue on my R7000 .
