fr66
Apr 22, 2022Follower
R8300 5G channels
I'm trying to change the 5G channel to something in the range 100-165 but it only lists 36,40,44 and 48. This is for 5G-1. The 5G-2 allows me to do this. Check the screenshots below. Any idea how I c...
Apr 22, 2022Guru - Experienced User
There's not a fix.
One channel only goes from 36-48 and the other from 100-165. its designed that way.
