Arepollo
May 16, 2019Aspirant
r8300 is Only getting 2Mbps
Roommate has this router, and is only getting <2 Mbps on speedtest.
For some background - we have 75Mbps internet, coax is connected to the modem which has an ethernet cable to the wall. That ...
- May 17, 2019
Any specific reason for operating to routers at all?
Forget about crappy bridge or repeater operation modes, as you have a nice in-house network cabling. Keep all routing on the R7000, and operate the R8300 as a wireless access point (if really required)..
Arepollo
May 17, 2019Aspirant
The modem is a Netgear c700 - modem only and not provided by the ISP. The r8300 router is on firmware version 1.0.2.130, just checked last night for updates. I double checked to make sure channels were not overlapping and right now the r7000 is creating a 192 network while the r8300 is creating a 10 network, so no overlapping IPs.
michaelkenward
May 17, 2019Guru - Experienced User
Arepollo wrote:
I double checked to make sure channels were not overlapping ..
That does nothing to fix the problem. It is irrelevant if you have to routers on the same network.
I repeat, you need to sort out the double-NAT issue.
Please go back and read ALL of the message I posted.
