Arepollo
May 16, 2019Aspirant
r8300 is Only getting 2Mbps
Roommate has this router, and is only getting <2 Mbps on speedtest.
For some background - we have 75Mbps internet, coax is connected to the modem which has an ethernet cable to the wall. That ...
- May 17, 2019
Any specific reason for operating to routers at all?
Forget about crappy bridge or repeater operation modes, as you have a nice in-house network cabling. Keep all routing on the R7000, and operate the R8300 as a wireless access point (if really required)..
michaelkenward
May 17, 2019Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
Arepollo wrote:
For some background - we have 75Mbps internet, coax is connected to the modem which has an ethernet cable to the wall. That connection goes into the patch panel where it plugs into a gigabit switch in order to feed the rest of the apartment wall ethernet ports. My router(r7000) is connected to one of these and my game consoles are wired to it, I am getting ~70 Mbps speeds both wired and wireless. My roommates router is connected to a different port, but the same way and is getting less than 2 Mbps.
That is a messy network that sounds like a disaster waiting to happen.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Maybe that is behind the speed issues.
Arepollo
May 17, 2019Aspirant
I DID, and if you read my info, that is NOT how they are set up. The modem has a line going to each router, they are NOT behind one another, so frankly that message seemd moot. Any other suggestions?
- michaelkenwardMay 17, 2019Guru - Experienced User
That does not fix the problem.
The C700 modem does not exist.
- ArepolloMay 17, 2019Aspirant
...? The description you send of double NAT required the routers to be behind one another. They are not. Obviously this doens't fix the problem or I wouldn't be on this forum in the first place. If you have a better description of what I can do besides just telling me it won't fix the problem (once again, obviously) then please share because clearly I'm not getting your point.
And my apologies for forgetting a letter. It's a cm700.
Quick self edit there. First it was a C7000 now it is a CM700.
I will leave you in the hands of Google:
How to Connect Two Routers on a Home Network
How do you connect two routers to one modem? - NETGEAR Communities
Or more:
two routers on one modem - Google Search
Sadly, the answer remains the same.
