Arepollo
May 16, 2019Aspirant
r8300 is Only getting 2Mbps
Roommate has this router, and is only getting <2 Mbps on speedtest.
For some background - we have 75Mbps internet, coax is connected to the modem which has an ethernet cable to the wall. That ...
- May 17, 2019
Any specific reason for operating to routers at all?
Forget about crappy bridge or repeater operation modes, as you have a nice in-house network cabling. Keep all routing on the R7000, and operate the R8300 as a wireless access point (if really required)..
Arepollo
May 17, 2019Aspirant
I DID, and if you read my info, that is NOT how they are set up. The modem has a line going to each router, they are NOT behind one another, so frankly that message seemd moot. Any other suggestions?
michaelkenward
May 17, 2019Guru - Experienced User
That does not fix the problem.
The C700 modem does not exist.
- ArepolloMay 17, 2019Aspirant
...? The description you send of double NAT required the routers to be behind one another. They are not. Obviously this doens't fix the problem or I wouldn't be on this forum in the first place. If you have a better description of what I can do besides just telling me it won't fix the problem (once again, obviously) then please share because clearly I'm not getting your point.
And my apologies for forgetting a letter. It's a cm700.
- michaelkenwardMay 17, 2019Guru - Experienced User
Quick self edit there. First it was a C7000 now it is a CM700.
I will leave you in the hands of Google:
How to Connect Two Routers on a Home Network
How do you connect two routers to one modem? - NETGEAR Communities
Or more:
two routers on one modem - Google Search
Sadly, the answer remains the same.
Or more:
God forbid people make mistakes? At least I double checked.
And if I wanted to only be in the hands of Google I would have statyed there and not come to a specific forum. Please get off my topic.
