Vvohra
Aug 06, 2021Follower
R8300 Whether Firmware update should be done from Version 116 to 154
My R8300 Nighthawk Router which I have not updated and is running on Firmware Version 116 , gives a lower upload speed of 52 Mbps and Download speed of 250 Mbps when doing a speed test. My Hardware engineer says the reason for the difference is because it has not been updated to the current Firmware version 154 . I tried doing it on the Nighthawk app but it shows an error. I am confused whether I should do a manual update at all and whether this will sort out the upload speed , as apart from the difference in the upload and download speeds I have no other issue.
Also I wonder whether doing the update to the current version without updating to the earlier versions may cause a problem to a working Router.
Please advise.
Please advise.
What modem/gateway is it connected to?
I prefer a manual update over a hardwired connection to any other method of update. Tends to go the smoothest and end up with the least amount of corrupt firmware issues.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- webleeGuide
Update no higher that 144 due to major issues with 154. if you have problems with 144 as I do - one more step down.
On the ADVANCED, WIRELESS page disable 20/40 co-existance for the fastest speeds.
