Gimli8892
Aug 19, 2022Aspirant
R8500 — NIGHTHAWK X8 AC5300 SMART WIFI ROUTER UPDATE WON'T LOAD
Trying to update from v1.0.2.122 - Android App shows v.1.02.160 is available but update doesn't work - failure message with no code - just offer to try again later.
Aug 19, 2022Guru - Experienced User
Try the manual FW update as suggested here:
Seen problems with updating FW using the NH app...not really recommended.
Gimli8892
Not helpful. The login link takes me into the netgear website to my account. Once there, I seem to be going in circles on the website.
You would think they would have a link to simply download the update.
- FURRYe38Aug 19, 2022Guru - Experienced User
Are you selecting the DOWNLOAD LINK seen in that thread? That will take you here:
Download Link: https://www.netgear.com/support/product/R8500.aspx#download
- Gimli8892Aug 19, 2022Aspirant
I appreciate your trying to help ...
Yes - I have multiple files from that download - one is a google link which takes me back to the page and the other is a .chk file (Recoverable File Fragments) which is not an executable file.
There are no instructions as to what to do with that file.- FURRYe38Aug 19, 2022Guru - Experienced User
Do not attempt to run that .chk file.
Use a web browser and PC and log into the routers web page and send that .chk file using the router web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
