CaledonKen
Mar 18, 2019Star
R8500 - Firmware 1.0.2.130 - Lost of Guest Network
Since I've upgrade my router firmware to 1.0.2.130 I've been losing Internet access on my Guests networks (2.4 or 5 GHz).
At first I thought it was a direct result of a security scan being done...
- Mar 19, 2019
Definitly Firmware.
Fell back to 1.0.2.128 and iPhones immediately had connection to Internet. No resetting. Firmware loaded and Internet access granted.
There is a REAL issue with v1.0.2.130. Interesting that Netgear is not aware. When fix ready would be happy to test.
CaledonKen
Mar 19, 2019Star
So I've continued to test and have an update. I need to power off reset my device this morning so starting from a new base.
I said my IOT thermostat continued to work. That had me puzzled. So I tried a Windows 10 computer and that worked. So when I say PC's can't connect I should have said iOS and Android devices can't get to Internet. They connect to Guest network but can't do anything on the internet. Weather, stocks, multiple browsers tried.
I reset the network on my iOS iphone 6S running iOS12.1.4 (up to date) and tried again. Same results. Wireless works on home network but unable to reach sites if I use Guest network.
- CaledonKenMar 19, 2019Star
I should add I did a full reset of router. Paperclip on reset button for 8 secs, when it restarted I got the full set up new router wizard, passwords, ssid's, etc had to be re-entered.
Another member, same issue, different router.
Definitly Firmware.
