alexandre3253
Jan 12, 2023Tutor
R8500 + EAX80
Hello, I have a R8500 purchased in US. I am traveling to Europe and want to buy the EAX80 extender. If I buy it in Europe, will it work with my R8500 purchased in US? Will they work or is there any ...
Jan 12, 2023Guru - Experienced User
EU has different broadcast restrictions.
And the north america versions are locked to north america.
Are you staying in EU long? If its permanent, buy the EAX in europe.
If its a brief stay, buy it in the US. You might have some broadcast issues but basically set your channels to avoid the EU restricted ones.
- alexandre3253Jan 12, 2023TutorThank you for your reply.
I will use both in Brazil. Besides the fact of local regulation I was wondering if they would communicate/work together. Thanks- plemansJan 12, 2023Guru - Experienced User
I've never tried mixing/matching regions to see if they'd work together.
I know the EU ones aren't region locked like the NA ones are. So potentially you could change regions on the EAX to get it working. Brazil's broadcast restrictions are pretty similar to the NA regions.
- michaelkenwardJan 12, 2023Guru - Experienced User
Long or short, buying in Europe might be best.
They don't lock the region here, going by all the things I have used. So you should be able to buy in Europe and than
switch to the US when you return home.
- alexandre3253Jan 13, 2023Tutor
Thank you all. I will let you know.
