alexandre3253
Jan 12, 2023Tutor
R8500 + EAX80
Hello, I have a R8500 purchased in US. I am traveling to Europe and want to buy the EAX80 extender. If I buy it in Europe, will it work with my R8500 purchased in US? Will they work or is there any ...
alexandre3253
Jan 12, 2023Tutor
Thank you for your reply.
I will use both in Brazil. Besides the fact of local regulation I was wondering if they would communicate/work together. Thanks
Jan 12, 2023Guru - Experienced User
I've never tried mixing/matching regions to see if they'd work together.
I know the EU ones aren't region locked like the NA ones are. So potentially you could change regions on the EAX to get it working. Brazil's broadcast restrictions are pretty similar to the NA regions.
